Weil-Mclain #AHE-45 - Ted Punskovsky
I am installing a Weil-Mclain #AHE-45 wall hung type boiler for a radiant heat system in a penthouse in NYC. The pump for this boiler is integral and has a built in mixing valve as part of thepump housing.
How can I use the pumping away arrangement with this type of boiler. By the way, i am installing a four waymixing valve and using primary and secondary type piping.
Where do I put the expansion tank and Spirovent so that i do not have any air problems.
Thanks,
Ted
