Venturi System - Master Plumb
HeavyP
Member Posts: 52
Can you use pex tubing to relocate 1/2" venturi branch lines (supply and return)? The reason I'm asking is that it would save me a ton of time, but i dont want to screw it up! I will use copper if I have to.Thanks in advance guys.Chris
pex & branch lines
Should work fine just make sure you put fittings the right way, I'm starting to see this stuff being used everywhere0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
