Small, small gyp pour - HR
hr
Member Posts: 6,106
Is it possible to hand mix a gyp product? A customer wants to level 110 square feet of a sloped slab to convert an old outdoor concrete deck into an extra room. The slope would be from say 1/4" to 1-1/2" in a 10 by 11 foot area. Any other ideas? Thanks
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
they make
floor levelers for fixing stuff like that, cannot think of the brand name ,this is sold at wholesale tile places,not home centers or lumberyards but if i do i will come back and edit.
this is good from 1/8 to 1'' i think, so you may need two pours, calculating the amount is the hardest part of job. but if you have a good dealer ,they may return a few extra bags,make sure you get enough
be sure to use the primers for adhesion to the old floor and (looks like elmers)the prouduct that you need is not the white powdery stuff, that does not work!!at all!!
and when mixing this (grey) it will looked like it is mixed within a minute, but you must keep mixing for 3 1/2 minutes to make sure it activates (we used a large "keg" barrel and a large beater from the tile place) if you need i'll lend you mine0 -
ok
the product we used is called "mapei"
heres the link http://www.mapei.com/
very good results with this
our east coast dealer is best tile
do not know where you would get it0 -
Is this a pour-able liquid product, similar to Gypcrete or Hackers or a trowel on paste type? I would like something that you could dump on ant it would float the floor level. Not that I'm being pickey
hr
definately
pour on. we mesured the water before the mix, then added or deleted every mix to be precise, we only trowled to put it into place then it leveled it self
and if you need extra thick, you have to let the first pour set up (day) before hitting it a second time, we used a RA drill for mixing, very important to keep mixing0 -
Water
The last I used (Armstrong)--grey like mentioned was very finicky about the amount of water. I used a bit less than the recommended water on the first batch--it was a velvety "cake batter" consistency--perfect I thought.
By the time I carried it up a flight of steps and to the rear of the house it was solid!0 -
gyp
Hotrod:gypsum concrete can be hand mixed butitdoesn't self level aswell as aportland based product. mapei is portland based. the down side is the portland based product will shrink a lot at 1-1/2" depth. The proper method is to use some washed pea gravel fill in the deep area. You must prime all privious lifts before repouring on top. call me if you want to talk. We do these all the time. 716-649-57230
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
