dial up Wall users ...
Sven
Member Posts: 34
In the options menu, located under the "find a contractor sign" are some useful functions.
One is a setting that says optimize for low speed connections - check it if you dial up.
There is also a box to check off if you only want to see new messages.
Also there is now a search button just before the options button with some brains to it :)
