Looking for thoughts ASAP: Viessman B1HE120 vs Weil McLain GV90+ series
Hello,
I have found the advice on this website very helpful, so I was looking for insightful opinions. This is our (family of 4) second year in our current home. The home has a Utica Boilers MAC 150 wall-condensing unit powering 4 heating zones (2 in-floor radiant, 2 baseboard zones) and indirect domestic hot water. It is powered by propane. There is a mix of copper plumbing at the furnace, but there is also a fair amount of pex through the house for heating. Suffice to say, the unit has developed issues that will be cost-prohibitive to repair and replacement is best solution. I live in the part of NY that most people don't even know exists, so we have some cold winters (think Canada, eh?) and the season is hitting fast. Hence why I want to make a decision ASAP.
The area is also rural, and reliable HVAC contractors are hard to come by. I managed to find a contractor that has a good reputation and has been very helpful. They quoted me 2 options for replacements - Viessman B1HE120, which would also be an on the wall condensing boiler - or the Weil McLain GV90+ series. Google AI touts the Viessman's efficiency and smart controls. It also touts the GV90+ series for its traditional cast-iron boiler and 'wide waterways for older hydronic piping.' I used to be all about the latest and greatest tech, and now my old age has shifted my perspective more towards the keep-it-simple, less to break mentality, LOL.
We have the floor space for a boiler, so being wall-mounted isn't a deciding factor for me. I like the idea of a cast-iron boiler. I plan to make sure to follow all maintenance and servicing recommendations for optimal upkeep. The domestic hot water will be used year round while the heating will be more seasonal. Thoughts on the 2 units? Thanks in advance!
Scott
Either one is probably fine. Viessmann is usually considered top of the line. Nothing wrong with Weil McLain either. How long did the Utica last and what is wrong with it?
You're lucky to have found (hopefully) a good contractor in your location. I live in MA but worked very little in upstate NY which IMHO was like the wild , wild, west.
Hello, previous owner didn't leave any documentation, but tag inside is dated October 2019 (I think that's the factory inspection tag). There's evidence of leak of heat exchanger supply line, on the side of the exchanger itself, and at least 2 locations on the front of the heat exchanger, and all the accompanying sensor/valve corruption by said leaks. I suspect that it was installed in a less-than-ideal quality job. They thought it might have been from hard water, but when testing the water it was ok. I can't find any tag or service documents to even indicate who installed it. Your comment about Wild Wild West is true. My parents live close by and have been through 3+ contractors due to various issues.
I guess that I should say that my previous 2 homes had older more traditional boilers (first house was a Weil McLane, maybe a GV90? and last house was a Smith boiler that was tanking along. So my first experience with newer more efficient technology with a condensing wall mounted unit leaves me nervous! But that is also why I'm posting hear to see what other more experienced professionals have to say. Thanks,
Scott
I've always heard lots of good things about Weil-McLain, but none of my wholesalers seem to stock them. We've installed Lochinvar and IBC boilers, but my preference these days is Viessmann and we've installed 5 of the B1HE models in the last two months and have another one coming up next week. Great boilers and excellent tech support. I have one in my house.
If you go with a Viessmann, make sure your installer knows to remove any check valves in the piping to your indirect as it messes with the diverting valve in the boiler. Also, make sure the expansion tank for the heating is on the return. More about that topic here. I also recommend getting the ViCare app. It monitors your boiler's operation and serves as the warranty registration.
Worth knowing the GV90+ isn't the old simple cast iron box. It's a condensing boiler too, cast iron primary plus a stainless secondary, PVC venting and a condensate trap, so the less to break gap is smaller than it sounds.
Weil-McLain rates it up to about 92% AFUE vs 95% for the Viessmann, and on propane those few points come back every winter. The Viessmann also turns down to about 14k BTU on propane, which is handy with small radiant zones that only need a trickle.
Out where you are I'd honestly lean toward whichever one your contractor installs most and keeps parts for. That's who you'll be calling in January.
Also very very few normal houses out there need a 120k boiler. Check how much propane you burned last year, converted to therms x 42 is about your actual heat load. For more accurate numbers run through the math here:
https://www.greenbuildingadvisor.com/article/replacing-a-furnace-or-boiler
Boiler leaking at fittings tends to be from bad water or extended runs at very high temperature with no ODR. Make sure the new boiler has an outdoor sensor and reasonable reset curve is set on it.
There is a lot of Weismann around me, that would be my vote.
- 136 Chimneys & Flues
- 398 Solar
- 16.2K Strictly Steam
- 52 Industry Classes
