Eurosit Gas Valve on 30KBTU Warm Morning Limit Control
I bought an older Warm Morning unit as auxiliary heat for a workshop, and wanted to get it going.
It's lacking the connection between the limit switch on the stack and the gas valve. The switch uses simple blade connectors, but the gas valve appears to want some sort of a pin-type male connector, and I need to figure out just what that is, or whether the connecting piece might be available from a parts supplier.
Images included of the valve badge and what I assume are the connecting points for the limit switch connection.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
