Seeking Guidance on Reconfiguration of Existing 2-Pipe Steam Radiator
I'm considering a reconfiguration of this radiator. The piping is less than ideal. It is the only one of 16 in the house that hammers and pops. It heats, but very slowly, and not evenly across. It's also the farthest from the boiler. This is in a bedroom which has 3 walls exposed, no insulation in the walls, and 4 newer windows. So we really need this one to deliver and it's not quite up to the task.
The radiator is not pitched, despite what the photo might show. It is level. I'm hesitant to pitch it up higher on the left, since the condensate will collect on the bottom right side and have no way of draining. Plus, the condensate return pipe is not centered to the bushing. The left end section does not have an outlet or plug at the top, so the valve must stay on the right side.
Note: Photos were taken in summertime, hence the AC cord laying against the rad, and it's since been moved. Since these photos were taken, I've added a TRV, a Danfoss 013G8018 body with an 015G4290 Aveo head, where there previously was just a manual valve. It has helped slightly but not enough.
Here is what I'm considering:
- Move trap to right side
- Add Hoffman 17C swivel trap
- Add a short 1/2 nipple into a 90.
- Plug the old bushing on the left side.
My questions:
- Is it acceptable/ideal to have both the valve and the trap on the same side?
- Any other unintended consequences which I am missing?
Thanks.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
