Water Level Going Up?!?! Shouldn't it go Down With Time??
I have an oil fueled boiler. I recently had some work done to fix my hot water. I don't have a separate water heater. I use the boiler to heat the water in my home. The heat has been running fine for a few weeks. I went to look at the sight glass the same day work was finished repairing my hot water. I couldn't see the fill line. The reason I couldn't see it because the water level was above where I could see it in the sight glass?! I just assumed the plumber accidentally over filled the water to my boiler. No big deal. I drained some water out. Two days later, I looked at the sight glass and I couldn't see the fill line again. Same thing. It filled up beyond the point you could see the fill line?! I called the plumber and he told me not to worry because this is normal. He said I probably just never noticed this before. Here is the problem: I don't have an automatic water feeder. I have to manual add water. I drained some water out again. The next day I carefully watched the sight glass. The water goes up a tiny bit with each heating cycle. The water didn't go up during the day while it was warm and the heating system was dormant. I think this rules out a leak in the feeder valve. The plumber says nothing he did on the water heating side would or should cause this. I would agree but there it is the water goes up and on the same day the work was done. I don't know if something happened or just dumb coincidence. He still thinks this is normal and believes the water is coming from the pipes because the pitch isn't as good as it should be. I don't agree that the water level should ever go above the point where the sight glass is useless. Any ideas? I am stumped. Thanks in advance!
