Part name & source for old fan switch
Hello HVAC community,
I am trying to fix up a very old furnace fan switch. I am using it in a semi-enclosed forge nowhere near a residence. The problem is with the copper plate in the switch that makes contact with the copper bump contacts. Anyone know what this part is called and if I can find one somewhere? I do not want to replace it with something newer (and likely enshitificated). There is not longer any markings or stickers on the switch. It likely dates to the 1960's.
Thanks for any guidance!
J
Thank you, mattmia2! The name should help me search a bit more. But if I can't get the part, or find a similar old switch to tear apart, I will just make a new wiper and keep it going.
Cheers,
J
there is probably some sort of a brush on a spring that kept pressure on both ends of it that broke or fell off
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
