the TACO 3350 union problem (not talking about labor, do they have unions in china, but i digress)
actually its kind of as issue for everyone. is there some reason the industry doesn't standarize here. i'd rather they compete on price, features, longevity, service, adjustability when it comes to boiler feeder PRVs. have 4 or 6 different unions threads is driving me friggin nuts.
the TACO which nobody uses anymore but used to be more prevalanet is 1" nominal actual 1 1/4 x 14 TPI.
In that size you also have the ould Honeywell/Braukmann which is what is installed on today's job which is 1" parallel pipe, i.e. 1 1/4 x 11.5 TPI. caleffi i forget is maybe 3/4 G union or 34 parallel pipe. the residio still makes the old standard but only in larger applications and uses 3/4 nom union for its 1/2 inch boiler filler PRVs.
is this really friggin necessary. every friggin season i forget how much of a PIA this was the season before and then I get a job like this where I looked quick. nut size and format said the TACO would fit. grabbed one off the shelf and no go. they don't even have a part number for a press fitting . $25 bucks if someone has it for a sweat type fitting that maybe I could just grab the nut cut the pipe swap nuts and press a coupling. come on you can get two TACO press by G union fittings for $25. I know it is a stocking and how many you move question. how about a bag of a dozen nuts so I don't get caught short.
so far @hot_rod has been right that the caleffi 533 series seems good on longevity but connectivity when I am just trying to swamp in a on a job I get called in on is so not there for this part of the industry. if they were to standardize on G unions as for pumps or something like that I could see it. nevermind you get a million different options on backflow preventers.
Am I just crotchety early this season. the grinch who stole Christmastat.
You have both thread compatability and also the "lay" length, overall length to deal with in a swap out.
I doubt all the manufacturers can get on the same page in both regards.
Living the hydronic dream0 -
Its always been that way.
Flanged gate valves and globe valves all the same dimensions. Take out a 6" 125# gate valve like a Jenkins and replace it with a Milwaukee or any other brand. Or replace it with a flanged ball valve like an Apollo. drops right in.
Control valve different story every time you change brands the dimensions change. Same with threaded valves like gate, globe or ball valves all different.
There are ANSI stsndards for flanges, so all brands will match.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
