Uneven defrost pattern on an outdoor heat-pump coil. What would you check first?
I watched my outdoor unit go through a defrost cycle because it seemed to take longer than expected to clear one section of the coil.
I used a thermal camera from a safe distance and could see that part of the coil was changing temperature differently from the rest. That narrowed my attention to the lower section instead of treating the whole unit as one problem.
I’m trying to decide what to investigate first before calling anyone out.
Poll: What would you check first?
  • Defrost sensor or control issue
  • Airflow around the outdoor coil
  • Refrigerant charge or distribution issue
  • Drainage or ice buildup near the bottom of the coil
  • Need more operating details first
Uneven defrost pattern on an outdoor heat-pump coil. What would you check first? 1 vote
0%
0%
100%
EBEBRATT-Ed 1 vote
0%
0%
