One radiant zone looks cooler on a thermal scan. What would you check first?
One part of our radiant floor feels cooler than the rest of the room once the system has been running for a while.
I used a Thermal Master P1 to compare the floor pattern across the zone. Most of the room showed a fairly even pattern, but one section looked noticeably different from the adjacent area. That gave me a clearer place to start instead of guessing below the finished floor.
The manifold is accessible, and I’m planning to inspect that next. Before I start changing settings, I’d appreciate input from people who work on radiant systems.
Poll: What would you check first?
- Air trapped in the loop
- Flow meter or valve not fully open
- Manifold balancing issue
- Circulator or zone-control issue
- Need more system information first
One radiant zone looks cooler on a thermal scan. What would you check first? 0 votes
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
