Using thermal imaging to trace a domestic hot water recirculation loop
The upstairs bathroom is the farthest fixture from the water heater, and it has always taken much longer to get hot water than the rest of the house.
I used a Thermal Master P1 to scan the accessible hot-water and return piping after running a hot tap upstairs. The supply line showed a clear warm path toward the bathroom, but the return side did not look consistent through the full accessible run.
That gave me a much better starting point than simply timing the tap. I’m now focusing on the recirculation pump, check valve, and the return path instead of treating the whole system as the problem.
For anyone who works on domestic hot-water recirculation, what would you check first when the supply appears warm but the return pattern is uneven?
Using thermal imaging to trace a domestic hot water recirculation loop 0 votes
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
