Using thermal imaging to compare baseboard heat on an older hydronic loop
bkudu
bkudu Posts: 3
I picked up a Thermal Master P1 because one room in my house always seems to lag behind the others when the heat is running.
I’m still new to thermal imaging, but my first pass was useful for comparing the baseboard pattern from one end of the loop to the other. Instead of just feeling the covers or checking one spot with a thermometer, I could see where the temperature pattern started changing along the run.
One section looked noticeably different from the rest, so I now have a more specific place to start looking at flow, balancing, or air in the loop. I haven’t opened anything up yet. I only scanned the outside of the baseboard and accessible piping.
For those who work on hydronic systems, what thermal pattern would make you look for air versus a flow or balancing issue?
