Who sells a single supply manifold for a radiant heat system?
I am interested in replacing only the supply manifold in my system so that I can configure with contemporary actuators to replace my antiquated Telestat actuators mounted on a Wirsbo manifold.
Strangely (to me), when I survey the marketplace (e.g., Uponor, Pexuniverse, SupplyHouse, Amazon, Home Depot, Lowe's), virtually all manifolds are sold in pairs: supply manifold coupled with a return manifold. Why is this? Doesn't anyone offer a single supply manifold for multiple loops? 🤔
You can replace the old actuators with new uponor actuators. If the old manifold is brass and says "WIrsbo" on it you just need to add a VA33 adapter with each new uponor actuator
https://www.supplyhouse.com/Uponor-Wirsbo-A3023522-Thermal-Actuator-Four-Wire
This would be the least expensive, and least intrusive method. Anyone can go replace all this stuff with maybe a youtube vid tutorial for confidence 😁
If you are positive you want to replace the supply manifold the only way I know how with new in box stuff would be to buy the manifold as a set and then replace just the supply portion. its a waste if there are no issues with the manifold though, the brass should last a lifetime
If you could get only the manifold you want without the other manifold, how much extra would you pay for it? I would be happy to sell you the parts you need from this Manifold set, for $399.00 and I will throw away the parts you don't want for you. you never need to know about it.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
