Navien recirc pump power supply
Got a Navien NCB-190/060H with a Grundfos Comfort 10-16 recirc pump wired to the PCB. Recirculation is set to External > Always On.
After startup the pump terminal has power for about 5-10 minutes, then goes to 0 V. It only comes back when I run a lot of hot water, so I'm already waiting 30-60 seconds for hot water by then. It has worked bettter before. Actually, until a few weeks ago, I could hear the pump running non-stop an we had instant hot water. I’m not sure what changed, other than I restarted the unit.
Can anyone tell me what actually triggers the power from the Navien boiler to the pump on the PCB? It appears “Always On” does not mean power is always provided for the pump. I measured the voltage and it goes to 0 after some time after I start the boiler up.
I was also wondering if I should plug in the pump directly into an outlet and let the pump decide about the operation mode. I believe this is how these pumps are supposed to work but I’m concerned it would have other implications (pushing constant cold water into the boiler, messing with DHW priority or alike).
Thanks for your feedback!
