Triangle Tube Phase III PG-45 Boiler Dead
I've gotten so used to a screen and some kind of diagnostic readout on a boiler when there's a problem, but there's no such thing on this one and it's not making heat or hot water. I'm hoping someone has some experience with them and can point me in the right direction.
Currently, I'm focusing on this relay being defective and there no diagram to show me which terminals are for the 24 volt coil and which are for the switching contacts. It looks like a double pole, double throw relay. The unused terminals are either normally open or normally closed.
The smaller relay behind it is straightforward: single pole, double throw.
