Lochinvar Knight - 0-10v control termination
Gotta think someone else came across this, Lochinvar Knight KHB155 comes with a separate Grundfos ECM circulator for the boiler primary loop and can be controlled by a 0-10v output.
My problem, the modular plug low voltage cable for the pump has three conductors (blue, black and brown), the control board on the boiler only has two terminals listed 0-10v +/- (see photo), which 2 of the 3 conductors are utilized? Nothing mentioned in the operator or service manuals, no instruction with the control cable either. Anyone?
    109A_5 Posts: 4,735
    You would have to look at the install manual for that circulator model. Since you did not provide us with the circulator model this is all I got.
  • Domark68
    Domark68 Posts: 8
    109A_5
    Thanks much for the diagram, that says it all. Brown would be + and Blue -, can’t believe no illustrations with either pump or cable. Apple the quick reply.
  • Brown +
    Blue -
  • Domark68
    Domark68 Posts: 8
    edited November 6
    appreciate! Damn spellcheck!
