Do simple calculation tools help when learning heating system sizing?
I’ve been trying to get better at understanding how different calculations are used in technical subjects, particularly when the numbers aren’t quite as straightforward as they first appear.
I originally ran into this while working with baseball statistics. For example, an ERA calculation looks simple, but innings such as 5.1 don’t actually mean 5.1 in decimal form. I was using a Baseball ERA Calculator to check the math, and it made me think about how useful calculators can be when learning what the numbers actually represent rather than just getting a final result.
That brought me to heating calculations. Heat-loss estimates, boiler sizing, flow rates, and temperature differences seem to have a lot more variables involved.
For someone learning residential heating, which calculation would you recommend understanding manually before relying on an online calculator? Is heat loss the best place to start, or are there simpler calculations that help build a better foundation?
    EBEBRATT-Ed Posts: 21,287
    Yes. Heat Loss Calculations are the first place to start. Calculators are great to shorten the time to do an accurate calculation.
    But they are just #s. They give you no understanding of heat loss or heat gain and how temperature and humidity move through a building. reading and understanding a Manual J will set you on the right track
    You could purchase a " Manual "J" from the Air conditioning Contractors Assn. They are $165.00.
    Older used ones are available on E-Bay for around $80 and are just as good. You don't need a new one to gain the understanding you need.
  • HydronicMike
    HydronicMike Posts: 462
    You can do a heat loss base on historical fuel used in a given time period, if you know the degree days between the periods, the zip code (for design day info) and the efficiency of the appliance.
    A former Wallie and a good friend of mine made one and used to post it here for people to have/download for free.
    hot_rod Posts: 28,639
    edited 7:12PM
    It's good to understand the heat flow basics. Understand the different inputs for wall and ceiling build ups, etc.
    Then you can look for problem areas when you run numbers.
    The Uponor design manual has a long form example.
    Find a load calc here in an Excel sheet.
    https://www.pprbd.org/Download/ResidentialHandout
  • mikehvacload
    mikehvacload Posts: 3
    Heat loss is the right place to start, and I'd go one step smaller: work a single room by hand. For each wall, window and ceiling it's area times U-value (1 divided by the R-value) times the design temperature difference, then add infiltration as room volume times air changes per hour times 0.018 times that same temperature difference. Once you've done one room on paper, a calculator stops being a black box because you can see which inputs move the number most, usually windows and air leakage. I build a Manual J calculator app, and the thing I'd tell any student is to run your hand numbers and the tool's numbers side by side for the same room, because the gap teaches you more than either result alone. If it's an existing house, checking your total against last winter's fuel use is a good sanity check too.
