Cracked radiator
Snowman56
Ive got a job with 2 cracked radiators with significant leaks. Im having a hard time finding a replacement radiator that will fit in the space and have a similar btu to the original. They are both short at 17 inchs off the ground and one is 60 inchs wide and one is 33. They are both about 14 deep. Does anyone have any distributor that build custom new cast or have refurbished I could look into. Any help would be appreciated.
Where are you located? Can you pick the up? How far can you travel to get them?
Facebook marketplace.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
