Radiator cold
Hi I wanted to run this by if anyone can help. I have a crown boiler in basement and the heat to 2nd floor bathroom and kitchen radiator is cold. Before the kitchen would get warm now freaking living room is good but bathroom and kitchen radiator not warm. I tried bleeding them other radiators in other rooms hot. What could be the problem. Is the pump or low pressure in system. Heating guy's coming here cant figure it out. Please let me know if anyone has a better solution to this. Thx
    i assume this is hot water? possibly converted gravity?
  • Juicer
    Juicer Posts: 9
    Yes second floor apartment
  • Juicer
    Juicer Posts: 9
    There is not one reply to this post. Do we not have heating professionals anymore. Please see post and recommend a pro
    Steamhead Posts: 19,007
    @Juicer , where are you located?
    Semi-retired
  • Grallert
    Grallert Posts: 1,237
    Can you tell us more? you haven't given much to go on. Can you post pictures of the boiler and system? Controls pumps and gauges?
    hot_rod Posts: 28,704
    circulator not running? You will need some tools to start trouble shooting
    A electrical meter to see if the pump has power is a first step
    Grallert
    edited April 1
    we asked you some questions and didn't get a response. the things that cause an emitter not to heat with hot water and with steam are very different. It appears your system is hot water from a few things you said but we need to start there.
    If you click on the little squiggle thing at the top right of the post it will send you e-mail when someone comments on it.
    As it gets warmer there tends to be less activity on here.
