21 Year Old Water Heaters Working well
seattlehiker
Member Posts: 14
Should I get ahead and replace them (see my pics of my setup)? Should I go to one Viessmann for both the potable and radiant heat, or use one and branch? I could abandon the Kitec (used ONLY for heat), but EVERY fitting is pristine because the guys USED THE CORRECT BRASS FITTINGS 21 years ago WITH A WASHER INSIDE THAT PREVENTS ANY REACTIVITY. Someone posted that I was one of the "rare" people that have no issues with this tubing. Perhaps because most Kitec installs were done using the cheapo/incorrect fittings, AND THEY USED IT FOR POTABLE. Funny how none of that was mentioned in the lawsuit.
Blackjack!?!
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
