Legacy Hot Water Heater
Greetings,
I’m inquiring about service and parts for a hot water heating tank manufacture by TRAGESER Copper Works Inc.
JFK / Idlewild Area
Jamaica, New York 11430
Unit Details:
• Model: CR40B
• Serial: B316311
• Era: Likely mid-20th century copper tank construction
What We Need Help With:
We are specifically looking to service or replace components related to pilot light operation and burner ignition, not replace the tank!!!
Potential components we are trying to identify or source include:
• Pilot light assembly
• Thermocouple
• Gas control valve
• Pilot tubing
• Ignition / safety control components
• Thermostat or heat regulation interface
We need an ethical, competent specialist who is adapt at working with legacy systems.
Please contact Tony at 347–7 20–2020 and also my email baba.amc@gmail .com
    They usually have 2 problems. 1. The valve is obsolete and was delisted because it wasn't safe to begin with. 2. Don't have a taping suitable for a t&p valve of sufficient capacity and a way to get the temp probe in the tank. There are ways to replace the gas valve with a different setup but making the relief valve meet current code may not be possible. If it is just the thermocouple that should be a standard part.
  • Hi, Photos of the top of the tank and gas train would be helpful. I'm not remembering if this is an "external flue" heater. If so, the shank on a replacement gas valve will need to be a bit longer. It may not be hard to add a T&P at the hot outlet with a redo of that line.
    ps. What problems is the heater giving you?
    Yours, Larry
    Steve Minnich
