Triangle Tube Prestige 110 Excellence constant CH DEMAND call
The CH DEMAND call will not shut off. There is no call for heat confirmed with a voltmeter. I have reset several times and no change. It eventually faults out to BOILER PROTECTION.
  • I can switch it off and on by disabling the CH feature using the menu. The DHW side appears unaffected.
