Detroit area residential boiler repair who’s the best?
who is the most knowledgeable/ best boiler repair/ replacement service in the Detroit area?
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    edited January 26
    Did you search the FIND A CONTRACTOR feature here? Mad Dog
  • dabrakeman
    dabrakeman Posts: 1,038
    edited January 25
    @offdutytech has been on here a number of times and appears to run business out of Detroit. To this day I do not really know what "qualifies" someone to be on the list, whether there is some vetting or whether they just pay the bucks... The aforementioned seems to know what he is doing based upon some posts but I have no first hand experience. He at least seems engaged and knowledgeable. Some of the listed folks to me is still a blind shot. Can try PM'ing him https://forum.heatinghelp.com/profile/5540634/offdutytech One of these days I will probably need some assistance myself in SE Michigan so keep me posted.
  • mhjaq8603
    mhjaq8603 Posts: 27
    ok thanks, I have been figuring a ton out on my own and have worked through many issues so far. I’m just trying to find someone with a lot of legit knowledge. I had a couple guys out who “knew” about boilers and I still had to figure out stuff on my own because they were wrong on a couple things.
    @mhjaq8603
    @offdutytech posts here fairly often. We have seen pictures of his work. If you can get him that is your best choice.
    is it steam or hot water?
  • offdutytech
    offdutytech Posts: 260
    @mhjaq8603 If you like you can give me a call my info is on find a contractor. Fall to spring I pretty much do boiler work because I prefer it.
    Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
    edited January 28
    @offdutytech you might mention in your ad that you know steam and maybe something to show you actually know it. from your ad I wouldn't have even tried you for a steam job.
    This is what comes up in the search list, you should make sure steam comes up in the part that gets clipped in the search
  • offdutytech
    @mattmia2 thats a valid point. I'll work on that the next few days after I clear up the service calls.
  • dabrakeman
    Might even add something to your posts here to indicate your association with GrunAire. I never put two and two together in the last 15 years myself😄
