oil tanks prematurely leaking in connecticut
i live in trumbull ct i put my 330 tank in less than 25 years ago it leaked i changed it had to go with steel the roth would not workout easily and was scared tank would let go. i see granby now offers only a one year warranty on top fed tanks down from 10. my tank had 5 or 6 different places where oil was weeping out. my friend owns a large oil tank business near me he told me his business on tank to tank replacements is ten times what it was a few years ago. the supply house said its biofuel causing it. anyone heard of this
What does this mean? "the roth would not workout easily and was scared tank would let go."
I have heard about problems with biofuel on all sorts of items, fuel pumps, oil filters, OSVs and the like. They even make a Biofuel version of the TigerLoop. I am not surprised that your steel fuel tank is experiencing a problem.
The plastic inner liner of the Roth and the Granby version of the plastic tank should be impervious to the corrosive agents of higher percentage Biofuel mixtures. If you have a newer steel tank that is failing, then get a plastic tank.
1 -
it was easier for me to just put the same tank back didnt have to cut and thread. as for letting go tank was 3/4 full and i didnt want that on my floor.ive never used bio fuel and niether has almost all the customers of my friend with the oil tank business
is anyone else seeing premature tank failure
Here is law on biofuel in Connecticut, not sure how CT poster from Trumbull CT avoids biofuel oil, but im all ears? Regards, RTW
Yes, biofuel heating oil is required in Connecticut. Starting July 1, 2022, all heating oil sold in the state must be a low-carbon fuel blend containing at least 5% biodiesel. This requirement increases to 10% by July 1, 2025, and further to 50% by July 1, 2035. This legislation aims to reduce greenhouse gas emissions and promote the use of renewable fuels in heating oil. ct.gov+4
Here is link to the Connecticut LAW
1 -
ok that explains it thanks
