oil furnace parts and tune up tools for sale
for sale barely used Beckett afg f3 burner, Bacharach Smoke tester, Dwyer monometer, fan timer, orbital flare tool, more
I replaced my furnace with heat pump. It was installed new 2003 in florida in 1,100 sq ft house. So, not used a lot. Not used at all when I was away at work. Not used when I was sleeping.
sale:
Beckett afg f3 burner w\new nozzle & new pump. Includes 1 or 2 extra never used nozzles and the perfectly working old pump. New pump & nozzle have less then 1 hour use. pumps: a2va-7116 & 7116B. 200$ w/o used pump. 250$ with both pumps. Electrodes are only a few years old. Also have extra set of electrodes.
Bacharach Smoke tester & 2 packs of papers. used about 50 times. 100$. I bought new 10 years ago and only used it to tune this heater. So, it's basically in new condition. I accidentally bought an extra set of true spot test papers.
orbital flare tool bought new in 2022. used about 10-12 times. 50$
Dwyer model # 400-5 most accurate monometer (more accurate then any digital gauge). No carry case. 100$.
I bought as surplus. It had dried fluid it in. An engineer at Dwyer told me how to clean it out. It has a few cracks in it as purchased, but none breech the fluid area. Both air connectors were totally blocked and Dwyer told me I could just drill them out, as long as gauge is not laid down it is fine. Connectors allow air in either direction but stop fluid from spilling out. Still I bought two new connectors, but never installed them. Uses red fluid is A-101. I have extra fluid, but it is a few years old.
ST9103A electronic fan timer. 75$.
Bought new in 2010 because original was damaged by lightning.
R8184 G originally came with burner 75$.
about 40' new never used oil supply line copper tube tubing/Piping. Ends capped. 25$.
Gauges, as shown free with all above.
Fuel filter housing w\ 2 parker shut offs. Filter contains new filter & includes several extra new never used filters. Also 2 extra filter housings never used. Housings and filters free with all above. The used filter with shutoffs cant be shipped, so pickup only. All bought 2 years ago.
extra high temp sheet gasket material. free with all above.
ask for pics. allpaulcla@gmail.com
Buyer pays shipping or pickup in st pete florida.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
