Slow
How fast should a B & G 100 bearing assembly turn. I replaced the motor mounts, coupler and bearing assembly with new oil. Runs ok but seems slow. Don’t how fast it should run. Thanks
  • 1650 rpm, I believe.
    HVACNUT Posts: 7,784
    RPM should be listed on the motor rating plate. Laser tachometer to test.
  • Sung
    Sung Posts: 4
    Thanks Alan. I just don" know how fast the coupler should turn when I look at it.
    If it's pumping I wouldn't be concerned. They are all single speed motors so there is no way any miswiring can make it run slow.
    If it was running slow the motor would probably be burning up (smoking). Don't be concerned if the motor is hot they run hot.
  • Sung
    Sung Posts: 4
    Thank you very much
  • Intplm.
    Intplm. Posts: 3,162
    @Sung I remember the same sensation when I changed my first B&G coupler many years ago. Turned the thing on, and it had this quiet purring sound. Made me think it was too slow. Yours is probably fine.
    PC7060
  • Sung
    Sung Posts: 4
    Ok thanks.
    EdTheHeaterMan Posts: 12,951
    edited October 2025
    That was no PURRR. You just missed your kitty cat that morning when you started that circ, a hundred years ago.  t was just a quiet relaxing sense that you were in your easy chair with kitty at your feet as the warmth of the boiler engulfed the home as a result of your premier workmanship and dedication to detail and your customer’s comfort.
    For @Sung: The Bell & Gossett Series 100 motor is a 1/12 HP, 115 volt, single-phase, 1725 RPM, oil-lubricated motor designed specifically for Series 100 booster pumps.
    Intplm.
  • Intplm.
    LOL, I mean really LOL. But yes. There was that too.
  • leonz
    leonz Posts: 1,994
    I miss oiling my 1953 B+G circulators, changing the spring assemblies on them took a while with my fat paws.
    Intplm.
  • 1725 RPM = ~30 revolutions per second. Never really thought about it, but that's fast.
