Radiator Air Valves
When replacing a radiator air valve, should one use pipe dope, Teflon tape or nothing at all?
    EdTheHeaterMan Posts: 12,948
    edited October 2025
    I find that you really don't need any sealant.  But if you must, stay away from teflon tape because you do not want to get stray flakes of teflon to find its way into the valve mechanism and cause it to fail.  A very small dab of pipe dope is all that you really need… If you must. Bottom line is to keep stuff from entering the valve opening so it does not get in there to foul the mechanism.
    Wahermgambuzza
