Oil furnace rumble and smoke
I have a Becket Model "A" "AF" and it was rumbling when I tried it and the fan ran smooth before the rumbling stated. Now I get smoke from it around the the burner. Can anyone explain what might be happening?
A Beckett that is operating properly does not "Rumble" or "Make Smoke". What is happening is you have a burner that needs professional attention. Do Not operate it any more because all that smoke is making the repairs needed more complicated.
Do you have the recommended annual maintenance for your oil burner heating system? It may be a good time to start on an annual maintenance program with a qualified professional.
2 -
