pressure/head loss, resistance of baseboard loop
Background: am replacing current baseboard heater/boiler cuz it could not keep house at 70F this past winter. I have 5 quotes/bids that differ GREATLY as to equipment & price. 3 utilize primary/secondary setup, while 2 say primary only is fine for my single loop situation. We have mild winters, one week at 20F. I want to figure the pressure loss in loop to help me evaluate the circs being suggested. Which of the following would you trust more:
- First principles: length of baseboard piping (house perimeter) + elbows + up/down into crawl space = 286 equivalent feet. 3/4" copper @ 8gmp ⇒ 25 psi loss or 57 feet.
- Use existing pump curve & current flow: Grundfos UP 26-99F @ 4gpm ⇒ 30 feet head.
#2 include loss of boiler, whereas #1 does not.
Are these two close enough to size new circ pump to then compare what is in the several quotes? Please don't wander too far from my Q.
THX.
- 8 gpm is way to high of a flow rate for 3/4 copper, 4 gpm is best practice,
- 4 gpm in 3/4 copper type M is 2.5 fps velocity.
- .016 psi/ ft pressure drop. So call it 300 feet of equivalent length gives you 4.8 feet of heat
- So the circ spec is 4 gpm at 4.8' head. Well within a small residential circulator.
- Pressure drop through the boiler depends… a basic cast boiler next to nothing. A restrictive mod con would be more restrictive, that is where primary secondary or a hydro sep comes in. Separate the two circuits.
- 8 gpm in 3/4 copper would be 5 fps (feet per second) velocity, that will be noisy and cause wear in the tubing and ells. 4 fps is about as high as you want for velocity. Rule of thumb 2- 4 fps.
Living the hydronic dream0 -
Why wouldn’t you figure out the btu requirements first? Then all sizing flows off of that.
