Mitsubishi mini split service/repair, Kingston NY area
Looking for competent service, reasonably priced, in the Kingston NY area.
Have an indoor unit MSZ-FH12NA that has been recharged once, due to a supposedly leaking indoor coil. It stopped heating/cooling again within half a season. Since then it has been idle
Recently found an MSZ-FH09NA, never connected, which has, per the parts list, the same coil. Seemed like a deal to me as I could salvage the "vane unit" to fix another indoor unit with a broken linkage.
So, I'd need someone to replace the coil, or, replace the entire unit. My understanding the only difference is the "control board", again, per the parts list. So, the board could be swapped, or, maybe, just let it be a 09 unit. I think it is oversize for that room anyway.
Thanks for watching.
