Slant Fin B200
L_I_John
L_I_John Posts: 1
edited April 2025 in THE MAIN WALL
My B200 keep timing out with the error codes A01 or A02. I have to keep resetting it. No one knows what the problem is. What can I take out and replace it with?
e it with. It has 5 zones.
    109A_5 Posts: 4,780
    edited April 2025
    Were these things checked ?
    https://s3.amazonaws.com/s3.supplyhouse.com/manuals/1282657809967/37801_PROD_FILE.pdf
    109A_5 Posts: 4,780
    Also understanding where the unsuccessful ignition and/or loss of flame happens in the operation sequence may help.
    EBEBRATT-Ed Posts: 21,353
    @L_I-John
    You don't throw away a perfectly good boiler because it won't run. If the technicians can't find the problem its because they haven't looked.
    Check "find a contractor" on this site
    And post your location we may know someone that can help.
    Are you on Long Island?
    109A_5 Posts: 4,780
    Also if the gas valve seems to randomly close or just not open, The 120V section of the Argus PHC794-S1 control board could have a failing solder joint and/or relay.
