When did pressure relief valves become standard?
T & Ps have been on water heaters as long as I can remember. But MA is pretty strict and used to publish their own plumbing code so maybe that is why.
I do remember when WH did not come with one and you had to buy and install one.
MA requires vacuum breakers and some states still do not.
I believe most states do not require vacuum breakers.
Pressure cookers need a relief valve. My mother & grandmother always used it. Mad Dog
but they can get clogged with food.
Then they make a new relief valve in one way or another.
I have had a few pressure cookers never a problem if you use your head. They all have relief valves now. They can get clogged with food.
When she is steaming as long as you keep the heat low and here the relief valve jiggle while it is cooking your fine, that means it is relieving steam. If you don't hear it jiggle you either ran out of water and your stuff is burning or the relief valve is plugged.
Before my wife passed on she wouldn't go in the kitchen if I was using it.
Steam is hot, it cuts the cooking time by quite a bit
I like it it's as close as I get to a boiler anymore.๐๐๐๐
I only use it for canning
Interesting code since top fed tank heaters all use a dip tube. Why does it being "bottom fed" matter in regards to needing a vacuum breaker or not?
This entire time I thought the reason for the vacuum breaker was to prevent caving the tank in if a line breaks at a much lower elevation.
Never thought about backflow prevention or dry firing the heater.
I've canned Lake chubbs with my buddy Harold after we caught last a bunch in Moosehead Lake in Maine. A lot of fun. Mad Dog
