Cast iron boiler replacement help
My Slantfin boiler recently cracked after 30 years of service and I need some advise on a good, but inexpensive cast iron model to replace it with. I live in Colorado at about 6500 feet altitude. I do not need or want high efficiency and it supplies heat to the hydranic heated floors. The domestic hot water is supplied by a stand alone water heater. I am getting some big quotes back and just want to make sure I am not getting hosed, no pun intented. Anyting else to consider in the boiler replacemant?
Also what is a typical markup for purchases by the plumber?
Thanks, Tripp
  • tim smith
    tim smith Posts: 2,935
    Give a photo of your existing installation, with all manifold piping in the photo along with boiler.
    Don't talk $$ on this site but at least can see what your up against. Prices have gone pretty high these days. BTW maybe you are just getting piped and not hosed! :)
    Mad Dog_2
    Weil McLain or Peerless. Prices are way up. just the way it is now.
    LRCCBJMad Dog_2
  • Big Ed_4
    Big Ed_4 Posts: 3,585
    Oil or gas ? What supplies the domestic hot water ?
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    Did it ever occur to you that this SF boiler failed because it could have been improperly installed/piped since it went in? A radiantly heated building with a cast iron boiler MUST be carefully piped out.
    Keep an open mind please, I know you don't want to spend alot, but it may very well make more sense ($$$) to use a more modern Condensing boiler on this low temp radiant system. Mad Dog
  • Mad Dog_2
    Tripp....please put up some pictures of the boiler & existing piping configuration? Mad Dog
  • Mad Dog_2
    I want to clarify that you mean radiantly heated floors...mad Dog
  • psb75
    psb75 Posts: 1,181
    Not much good news for Mr. Tripp.
  • Intplm.
    Intplm. Posts: 3,160
    I would suggest choosing your contractor as much as the boiler manufacturer. A company that will install AND service your new boiler should go hand in hand.
    jringel
