top floors not getting that much heat
Hi,
we currently have a gas steam boiler by Dunkirk. The top floors don't get that much heat and if it does go up one room gets the most heat. Also there is a ton of banging when we put the heat up.
Any suggestions would be great.
Thanks!
Your vents on each radiator may need attention, you may also have the pressure set too high
There are other causes. Can you post photos of your boiler in the basement so we can see the connecting pipes from the floor to the ceiling?
1
