Bosch/Greenstar Replacement Ignitor Wires?
I've got a Bosch Combi boiler that we use as a back up every so often when it's too cold the heat pumps. Went to fire it up and discovered some mouse activity in there.
Can anyone point me in the direction of the parts number for the electrode wires? They'll definitely need replacing. Damage looks minimal so far.
Looks like number 14. May not be the correct part number, since you did not include your units model number. Look in your manual or a manual for your unit for the correct number, then Google the correct number to find an on-line vendor or see if your service provider can get it.
I'd figure out how they got in and block their ingress with a screen if necessary.
One Pipe System0
