Well tanks.
Interesting video on well pressure tanks. I don't know if bladder expansion tanks for heating systems are constructed the same.
I always thought for some reason that the air pressure was in the bladder, but it isn't the water is.
Interesting that the Amtrol Tank was of poorer construction and failed. I found it interesting.
PC7060
  • Intplm.
    Intplm. Posts: 3,160
    He did a nice job on the video.
    I have never had anyone be able to define why the cut-in pressure needs to be two psi less? Does anyone know?
    These tanks I have found will rust from the outside in when there is just a very small scratch on the paint. They need to be handled very carefully or they will leak prematurely from even the smallest paint damage. When he used the vinyl razor blade to cut the bladder on the horizontal tank, I noticed some paint missing. That might the reason for the "sand" as it may have actually been rust build up, if not a combination of both. Cool video.
    EBEBRATT-Ed Posts: 21,328
    @Intplm.
    I don't know why they spec a few pounds under cut in but I have heard that from several people so it must be accurate.
    I think they want to take full advantage of a collapsed bladder to minimize the pump cycles.
    Intplm.
    hot_rod Posts: 28,699
    The well tanks are similar to bag or bladder type hydronic expansion tanks, where the fluid is inside the bag
    @hot_rod Yeah I always assumed the air was in the bladder.
    Pre-charge info from Wessel
    Intplm.
