Hi could somebody tell me what the difference is in these hago nozzles
hi could someone tell me the difference in these two hago 0.50 80H nozzles one is in a clear top container and has a different shape filter and the other one is in red top container and has a different shape filter -thank you
Age.
The red top nozzle vial has a nozzle that was made within the last 10 years. the clear top vial was from an older batch of nozzles. There is no actual functional difference. They are the same.
I can tell you this about those two nozzles, now that they are out of the factory container, if you have touched the cindered filter with your fingers, no matter how clean your hands are, you can throw both those nozzles away. Proper nozzle handling recommends that nothing touches the cindered filter except the oil that it is to filter once it is installed in the oil burner's nozzle assembly. Especially the nozzles below 1.00 GPH, the orifice for that nozzle spray along with the tangental slots inside the nozzle are very small and can get clogged easily
2
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
