Hvac, Hydronic system technician license, course and permit in NJ
Do you you have an NJ plumbing license yet?
NJ is still learning about HVAC License rules and regulations. They only started offering the HVAC license about 10 years ago.
There is an apprentice process that you need to go through to get the HVAC license, Just like Plumbers and Electricians. There is nothing like just taking a test to get a license. There is no Hydronics license. You can get a NJ State Home Improvement Contractors license with proof of insurance and filling out a form. That will get you the ability to pull permits for jobs that do not need an electrician or plumber. Installing a boiler or a furnace will fall into that category in many cases. You will need the electrician friend to get the electric hookup and perhaps the plumber friend to install the water feed to a boiler. But Gas piping, oil tanks, ductwork, and Hydronics piping do not fall under the plumbing license and can be installed by anyone with a brain. The home improvement contractor license can get you that permit if one is required. You just need to have some plumber and electrician friends to get the other two forms sealed to apply for a permit.
As far as maintenance and repairs are concerned, you don't need permits to make repairs and therefore you do not need a license. Having the Home Improvement license is a good start for now.Edward Young Retired
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
