Gauge tapping clogged?
After a boil, as the condensate returns, the water level in my gauge glass goes way up - over the top of the glass - but it's a false reading. It's like there's a syphon holding it up there. If I draw a cup of water out of the blowdown, it drops back to the actual water level - 1/2 up glass. Do I have a clog in the upper tapping?
Homeowner in Middletown, PA
1936 house with 1996 Burnham V74 oil-fired 1-pipe system
  • Pumpguy
    Pumpguy Posts: 808
    Not likely.
    I'm thinking if the upper fitting was clogged, the air in the glass would compress and the water column in the glass would rise only a little, if any at all.
