Radiant 2 Zone System Stat Reccomendation
cloudedaze13
I have a Weil Mclain boiler system with 2 zones. Currently I have 2 nest thermostats and I'm wondering if I could be running better thermostats for efficiency and performance. I have these setup with a C wire.
What's the best option for a boiler radiant system?
Stats run from mild to wild. Do you want WiFi? Digital, setback functions? Or a simple no frills heat stat.
I have had Ecobee on my systems for years without any issues. I believe Honeywell has comparable stats.
Living the hydronic dream0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
