Wirsbro Panelpro 311p With Systempro 311 Controller
Is anyone aware of the Wirsbo System311 controller configuration setting that will shut down all of the pumps other than the DHW pump when there is a DHW demand? My controller continues to allow the main pump (P3) to operate when there is a DHW demand. Since the main pump is more powerful than the DHW pump water does not flow properly through the DHW loop. I just replace the System311 Controller with a new System311 controller that my plumber has had on his shelf for the last 17 years. I did not replace the wiring terminal blocks or change any of the wiring. Since the wiring terminal blocks unplug, I just plugged the old blocks into the new controller. I also did not replace any of the sensor, I used all of the old sensors. As you can see from the pictures that I attached the main pump (P3) is new, installed last year. The problem with the DHW started to occur shortly after the new main pump was installed. I am open to any other ideas that anyone may have, since this systems was discontinued in 2008, I can find anyone in my area (Kittery, ME) who has a clue as to how to diagnose this issue.
- 129 Chimneys & Flues
- 122 Geothermal
