Upgrade gas fired boiler for commercial building
Hello all, first time post looking for some advice. I have two Laars mighty max units providing heat to a commercial unit. I was away for the holiday and received an alert on my wifi water detector. Long story short water is leaking from the one unit. Due to age of unit over 20 years I will be replacing the unit or both. I am looking for too see what are the best options for my setup. I have a mix of baseboard and hot air throughout the building. I have a picture of my setup.
Thank you in advance
It looks like you can get a similar boiler that can be an easy fit called the Mighty Therm. This looks line the same boiler with a few upgrades.
This will be the least amount of redesigning
Thank you for the reply. Would it make sense to change to a tankless, or is that too much redesigning? Also since the other unit still runs should I just get the one replaced and see what happens.
Thank you for the replies. It has been very helpful.
