Help Wiring a Relay, Aquastat and Circ for a Steam Boiler Baseboard Zone
tcassano87
tcassano87 Member Posts: 149
edited December 2024 in Gas Heating
I have to reconnect a Basement baseboard zone to a new installed steam boiler. There will be a thermostat to control the basement. Looking for some help or a diagram on best way to wire the relay, circulator and aquastat together and to the boiler so it shuts down the circulator when temp his 180. Not sure if the photo I sent would worked I’m seeing the Aquastat should get its own power and then wire the circulator separately. C1 & C2 would feed the circulator obviously
Its a Burnham IN6 for reference
Using a Honeywell L4600A2007 Aquastat
Taco 007 Circulator
And either a
Taco SR-501 or a Honeywell R8845
