Inconsistent Shower Temperature
We just moved into our 120 year old house. When we go to shower we have about 2 minutes of hot water then the water goes cold. After about 10 mins the hot water will come back. This is after no other showers have been taken and no one has been using water for anything. We have oil and I will attatched a picture of our boiler I think it is. Could it just be the pressure? Or do we need to install a tankless system? Thanks for your help!
D9597A64-21D9-489E-AF5C-E61948BBD4B6.jpeg 71198610-7D29-4C03-BD72-931601CC73D6.jpeg
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,242
    You current have a tankless system, that’s the issue :). There’s no need for a new system at this point. Find someone to fix the current one.
  • LRCCBJ
    LRCCBJ Member Posts: 1,043
    Here is the critical question:
    When it goes cold………..do you leave it running at full hot for 10 minutes and stand away………….or do you shut it off and wait 10 minutes and try it again?
  • OldHomeProbs211
    OldHomeProbs211 Member Posts: 4
    we leave it running and deal with it cold. If you take a long enough shower you’ll get some hot water at the end.
  • OldHomeProbs211
    What exactly needs to be fixed on the system? Thanks for your help
  • LRCCBJ
    edited December 2024
    Good info.
    My suspicion is that the settings on the boiler are incorrect. If the boiler can recover and provide HW in 10 minutes, all it needs is an adjustment.
    Can you find the aquastat and take a photo of it with the cover removed? I am guessing from your photo that it is the grey box on the right side of the boiler near the top.
  • OldHomeProbs211
    Sorry for such a late reply. Here is a picture of that box with the cover removed
  • LRCCBJ
    You have the Honeywell L7224 control.
    Here are the operating instructions for it.
    https://customer.resideo.com/resources/Techlit/TechLitDocuments/69-0000s/69-1957.pdf
    Read it carefully and understand how to go into the setup for it. What I need to know is the HL (high limit) LL (low limit) and the Ldf (Low Limit differential).
  • BDR529
    BDR529 Member Posts: 376
    No tempering valave at the tankless? The anti-scaldvalve in the shower is having a fit
  • yellowdog
    yellowdog Member Posts: 294
    Replace the coil or have it cleaned.
    GGross
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,643
    You should have a thermostatic mixing valve on that domestic coil for preventing spikes & scalding. I always install a thermometer guage on the outlet so you know what temp is going out. Mad Dog
    GGross
