honeywell smartvalve
Hello,
I'm trying to find a replacement, repair parts, or repair services for a HW SV9570A2526 smartvalve. Everything I've found says it's obsolete.
Thank you for your time and expertise.
    EBEBRATT-Ed Member Posts: 20,476
    Is this for a water heater, boiler or furnace. Honeywell must have a cross reference if that # no longer exists.
    Honeywell is tough to contact they don't like talking to homeowners. You need to try a distributor who sells Honeywell to track this down.
    Try Control Consultants 1-781-335-8353 They are part of Kele now. In Weymouth , Ma.
    EdTheHeaterMan Member Posts: 12,504
    How old is the water heater?  Is the tank in good condition?  Based on available information and my experience, gas automatic water heater tanks last about one week past the warranty or about 12 years, whichever is shorter. A “well taken care of” tank would mean that you opened the valve at the bottom of the tank to flush out debris at least 2 times a year and you replaced the anode rod every 3 to 5 years based on your water conditions.
    That said, if you want to keep the tank and not purchase a new tank, you will need to redesign the pilot assembly to accept a different pilot and install a different gas valve. Does your tank use a power vent to exhaust the flue gas?
    After you have spent several hundred dollars on this project, and the tank starts to leak, that money you spent will be lost. It may be better spent on the replacement water heater. That all depends on the age and condition of your tank.
    Larry Weingarten
  • KarlW
    KarlW Member Posts: 184
    A quick web search turns it up for sale at supplyhouse.com and a host of other places. Try searching for “SV9570A2526 honeywell”
