Add IFC to Taco 007-F5
I've got a Taco 007-F5 without IFC and would like to add the IFC valve. My pump has a date code of "9 08" stamped in the electrical box & seems to have the machining for the IFC on the discharge side. The machined ID measures approximately 0.985". I see on Taco's Replacement Parts List that 2 different IFC's have been used in the 007's: 006-047RP & 0010-025RP. Can anyone tell me which one would fit my pump?
Thank you
  • SteveSan
    SteveSan Posts: 310
    Good morning, Tim. The correct IFC part# for your 007-F5 would be 0010-025RP.
    If you ever have questions about a Taco product, please call Tech Services 401-942-8000 Mon-Fri 8am-5pm EST.
    HVACNUTJohnNYMad Dog_2Dave H_2
  • TimH
    TimH Posts: 8
    Thanks for the help! I'll give that a try.
    SteveSan
  • SteveSan
    SteveSan Posts: 310
    @TimH You can check the windings to see if the motor is still good. Y-R 37-46ohms, Y-B 96-117, and R-B 133-163.
