Taco Circulator Cartridges
I have a brand new circulator cartridge that I do not know what it fits. It has the same impeller as an 011-009rp. However, the body that goes in the field case is about 1/2” longer than the 011 and just slightly larger in diameter than the 011. I have other 011, 009 and 007 cartridges to compare so I know it’s not those. Does anyone know if the 012, 013, 014, or 015 have a longer field housing?
    EdTheHeaterMan Member Posts: 12,324
    Is there a part number on it?
    There are several Taco Tech Support guys on here, They will know. @SteveSan is one of them
    SteveSan
  • SteveSan
    SteveSan Member Posts: 298
    Can you supply a picture and dimensions on the imp or any numbers on the imp?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,533
    Better off replacing the complete unit …
