Issue with Navien flow sensor
About five years ago we installed 12 Navien tankless gas water heaters model # NPE-240a. These were installed in several houses in the same neighborhood, on the same city water service. One of the units has had the flow sensor fail, three times within the last five years, since the unit was installed. the other 11 have operated without one issue. I have spoke with Navien and they don't seem to have a solution. Has anyone every heard of this or ran into the same issue? My first thoughts were higher then normal water pressure, but the pressure seems to be the same on the entire street, around 60 psi. Any ideas as to what could be causing these sensors to fail would be much appreciated. Thanks to all.
put a gauge like this on the system for a few days or a week. It will catch a spike from water hammer or a failed regulator
Living the hydronic dream0 -
Have you run the high pressure idea past navien tech support? according to their documents the unit is rated for 15-150PSI. is there an inlet filter on the unit? what do the failed flow sensors look like when you pull them out? what is the nature of the failure, electrical physical damage etc. multiple failures of the same part on the same install usually implies something else is at play imo. need more info
